Re: Results with Draft control
Posted by ZANE on May 03, 2018 at 20:06:44 [URL] [DELETE] :
In Reply to: Results with Draft control posted by Kimberly on May 02, 2018 at 16:43:11:
If the big spring at the top link is too loose when you try to lift the plow the draft sensing rod will be pulled backwards causing the touch control lever mechanism not to come in contact with the control valve linkage. The lift linkage in this case need to be adjusted. Sometimes if it has not already been moved all the way to the back you can get it back to lifting by loosening the four bolts that attach the quadrant to the lift housing and move the quadrant backwards far as it will go.
Zane
