Re: 58 861 Work light dimension
Posted by Larry TX on May 05, 2018 at 14:21:28 [URL] [DELETE] :
In Reply to: 58 861 Work light dimension posted by mike on May 05, 2018 at 12:34:20:
Those clips are semi-W shaped Mike. It takes 4 clips to hold the bulb in place and if you've never used them before when installing a bulb, it's a sorta-kinda difficult job to do, or at least getting started, so you might consider getting the help of someone. The bulb has to be placed in the ring and held in place, then the "wings" of the clip placed under the outer rim of the ring and the flat spot of the clip fits down over the lip of the bulb. Once you get two opposite clips in place, the other two are easy, just remember to not block the retainer screw hole in the ring when inserting the clips. Unity spotlights use the same type clips to retain the bulbs in their lamps. Hope this helps.
