Re: 8N with Ferguson TO20 hydraulic pump linkage and top plate
Posted by K.LaRue-VA on May 07, 2018 at 12:45:08 [URL] [DELETE] :
In Reply to: Re: 8N with Ferguson TO20 hydraulic pump linkage and top plate posted by Kevin on May 07, 2018 at 12:16:41:
No, The top plate for the 8N is different in order to add the small lever for position control. The bolt pattern is the same. I believe it is possible to swap 9N and 8N top covers as long as you also swap the pump that goes with the cover being used.
