Re: axle shaft bearing collar 9N-4132
Posted by K.LaRue-VA on May 07, 2018 at 13:29:54 [URL] [DELETE] :
In Reply to: axle shaft bearing collar 9N-4132 posted by Andy Wildman on May 06, 2018 at 07:30:20:
What, only missed by a few thousandths! That's pretty close for parts from the land of almost fits. I had a similar problem once upon a time, and solved it by taking a sharp cold chisel and "dinking" around the edge. Each impact groove displaces material to either side, increasing the overall diameter. A more professional method to do that would be to knurl the OD of the collars. That is a lot of effort/expense to make parts fit that should have been machined right to begin with. If we return more defective parts, maybe the quality will improve? Guess I can dream about new parts that fit right.
