Re: 641 governor spring and throttle arm
Posted by JMOR on May 09, 2018 at 10:24:46 [URL] [DELETE] :
In Reply to: 641 governor spring and throttle arm posted by Mike in Michigan on May 08, 2018 at 18:43:16:
If you can used fingers on carb throttle arm (not rod) to slow it (until next time you move throttle), then it will likely be a worn throttle shaft. The reason is that when throttle shaft wears, the throttle plate is pulled against the throat on one side before it can properly close, but with fingers, you can reposition it to center & close it.
