Re: Rear axle end play 2n
Posted by Tony C. on May 10, 2018 at 10:38:30 [URL] [DELETE] :
In Reply to: Re: Rear axle end play 2n posted by JMOR on May 10, 2018 at 05:07:13:
Good morning,
No harm, no foul and no offence taken.
It was a simple job. For some unknown reason I had too much end play in one axle which prompted the initial question. After I disassembled it to see what had happened I reassembled it and it went in easily with .020" end play. I have some .010 (+/- a couple as I used a guestimating digital caliper.) gasket material and made a couple gaskets. No end play, Everything is as it should be.
Cosmic equilibrium and a steady stat environment has been restored.
