Sherman install
Posted by Rick. D on May 12, 2018 at 21:27:22 [URL] [DELETE] :
Received my grandfathers 8n and have started the restoration and discovered the step up/down Sherman. I have studied the reinstall instructions at several sites and I pose this question. Why remove the Sherman multiple times for the preload on the bearings when the cup on rear applies the same pressure to the bearing cups. If I understand correctly with a Sherman you donít use the pound inch preload it is done by feel only. Thanks
