Re: 6 volt positive ground?
Posted by Bruce (VA) on May 16, 2018 at 16:23:58 [URL] [DELETE] :
In Reply to: 6 volt positive ground? posted by James Mort on May 16, 2018 at 14:28:08:
Well, if it has a 6v generator and a 12v battery, it's pretty obvious why the battery was always dead.
Look at the back of the generator; the 9 & 2N generators had an output adjustment screw. Does yours have one?
If it does, it's 6v for sure.
Tractor came from the factory 6v positive ground. Put a 6v battery in it & polarize the generator before you start the tractor.
See tips 23 & 51.
And tip # 39.
