Re: 860 pto clutch
Posted by Michford on May 18, 2018 at 05:37:08 [URL] [DELETE] :
In Reply to: 860 pto clutch posted by lonestarjeff on May 16, 2018 at 17:53:00:
Most likely stuck. I've been lucky so far with no stuck clutches with the limited use of my tractors. I just started blocking the clutches this past winter as an ounce of prevention. I tried the block of wood on the clutch pedal it self, but found it easier to block the clutch pedal by putting a small prybar between the clutch pedal stop adjust and the transmission housing.
