Re: 8n still sputtering...
Posted by Tony C. on May 22, 2018 at 12:27:25 [URL] [DELETE] :
In Reply to: Re: 8n still sputtering... posted by Jim on May 22, 2018 at 11:19:23:
Good gas, correct? How far did you go with the fuel system? Disassemble and clean out the carb and adjust it correctly. Possibly a chunk of dirt under the main jet? Needle valve? Or float sticking?
Bogging and dying upon acceleration can be caused by fuel shortage. Too much air too quick vs. amount of fuel, you get the idea. Picking up slowly and if you have to tickle it, advance weights frozen. Usually that only makes it just a little lazy picking up the rpm and maybe not getting full power.
TOny
