Re: Hydraulic lift sticking
Posted by JMOR on May 22, 2018 at 12:42:23 [URL] [DELETE] :
In Reply to: Hydraulic lift sticking posted by Mike on May 21, 2018 at 06:34:49:
Dirt & corrosion (rust). Outlet valve (lower) is not a direct mechanical connection like the inlet control valve (lift), so it is easier to stick enough that spring force won't move it. Located in base of pump.
