Re: Electrical harness, ignition problems
Posted by R Geiger on May 22, 2018 at 17:50:59 [URL] [DELETE] :
In Reply to: Re: Electrical harness, ignition problems posted by Marty on May 22, 2018 at 17:23:02:
The red wire that goes to the push button should be going to the small terminal on the solenoid. if you ground out the small terminal the starter should turn over. make sure the transmission is in neutral before you try this. if you have the correct solenoid the small terminal should point towards the block. It will not work if the small terminal is facing away from the block.
keep it safe
