Re: Electrical harness, ignition problems
Posted by JMOR on May 23, 2018 at 09:16:30 [URL] [DELETE] :
In Reply to: Re: Electrical harness, ignition problems posted by Marty on May 23, 2018 at 07:38:41:
Possibly wrong solenoid. There are many variations & some different (electrically) appear identical externally. From this diagram, you should be able to measure Continuity & or voltage and determine whether it is correct unit or not. You might just apply voltage (instead of ground)to the small solenoid terminal & see if it activates as a quick check to tell you that it is wrong type. BE SURE transmission is in NEUTRAL so as not to run over your self.
