Re: Stored 8n looking for advice
Posted by steveVa on May 25, 2018 at 05:52:19 [URL] [DELETE] :
In Reply to: Stored 8n looking for advice posted by End of the road 8n on May 25, 2018 at 04:05:08:
A 47 should be a front distributer with the square type coil. Could you see that the head gasket had been replaced? Water in oil could be leaked by head gasket. Could have a vacuum leak or carb pluged up. I would get it started before I did anything else. You should check or change the lift oil.
