Re: Vacuum?
Posted by Bruce (VA) on May 25, 2018 at 06:54:42 [URL] [DELETE] :
In Reply to: Re: Vacuum? posted by Rusty 2N on May 24, 2018 at 23:45:28:
Front or side distributor?
Get out the hand-held propane tank and spray it around the carb and manifold. If the rpm's increase, you found the leak.
Carb is probably sucking air around the throttle shaft.
