Re: 601 oil leakage from hydraulic sump to transmission
Posted by Ultradog MN on May 28, 2018 at 17:34:56 [URL] [DELETE] :
In Reply to: Re: 601 oil leakage from hydraulic sump to transmission posted by Richard NY 2N on May 28, 2018 at 15:42:56:
Send an email to support@yesterdaystractors.com
Give them your username and they will send your password to you.
Then login and post on the Ford board - not the N board there.
It's not that I won't help you but I do think you would get better results if you ask there yourself.
I'm certain they can and will help. It is a very good board.
Since you mention a shifter boot I assume your 601 is a 641?
If so title your post - Oil pushing out of shifter boot on 641.
I follow that board closely and will chime in if I can help in any way.
