Re: 3 pt
Posted by Bruce (VA) on June 02, 2018 at 17:53:48 [URL] [DELETE] :
In Reply to: Re: 3 pt posted by Lowell C Brown on June 02, 2018 at 17:08:19:
Yes, I understand it will not lift.
What I am trying to do is help you determine why it won't lift.
That's why I suggested the process outlined in tip # 16. Remove an inspection plate and try to lift a heavy implement. If you see fluid flowing from the top cover, that will help you determine the cause of the problem.
See tips 3 & 4 re fluid.
