Posted by Tim Daley(MI) on June 05, 2018 at 15:36:57 [URL] [DELETE] :
In Reply to: Re: Rear Wheel Removal and Handling posted by Kimberly on June 05, 2018 at 11:25:02:
Yes, the center discs are removable from the rims, and it is most always just the rim that gets rusted out. Filling the tires with liquid ballast is not a requirement, only a recommendation wen extra weight is needed. If your intents are for semi-light duty like plowing or mowing, and even moving dirt or snow, probably not needed. Have you used that hand-held sandblaster unit? What is the cfi? Here's a document from our MANUALS on the tractor jack...
