Re: Advice on ball joint lower lift arm
Posted by Rustyal on June 06, 2018 at 09:41:35 [URL] [DELETE] :
In Reply to: Re: Advice on ball joint lower lift arm posted by Kimberly on June 04, 2018 at 11:44:13:
Iíve seen large washers installed to keep it together. If you think there is a danger of it coming off get a new ball end welded on. It is probably going to be fine as is but be safe.
