Re: 8N Headlamp Wings
Posted by Kimberly on June 10, 2018 at 12:16:52 [URL] [DELETE] :
In Reply to: Re: 8N Headlamp Wings posted by Tim Daley(MI) on June 10, 2018 at 11:08:27:
Other wings I have seen are not solid but concaved; which is not the correct term. See the attached image. Those have bolts that go through and attaches the wing. The ones in the fleabay that I posted are solid and I guess the wings are held in place with the headlamp.
The tractor had headlamps but I think Dad removed them because they were so badly rusted and then they were not added back. All the holes are there including the switch holes in the dash. I am finding that light parts are not cheap.
Several moves have lost these parts as I have not seen them anywhere. I also lost a drawbar; we had the tractor stored at a friends house and it didn't come home with the tractor.
I would like the lamps back on the tractor. It also had all the rear lamps. I will look again to see if I can find any parts. Thanks, will contact you by email off sight. Thanks so much.
