Re: 8N lift not raising
Posted by Paul Wentworth on June 12, 2018 at 17:58:07 [URL] [DELETE] :
In Reply to: Re: 8N lift not raising posted by Tim Daley(MI) on June 12, 2018 at 16:18:18:
Glad I asked, Tim. I thought the bubbles were coming from air being trapped somewhere during the fluid change. It did improve after a few days of sitting. Since the lift works ok when the touch control is rigged to be able to go beyond the normal range in the quadrant, I thought the problem was a worn linkage or part. Looks like I've got some work to do. In addition to the manual and other reading, can you recommend a video or slideshow that shows the rebuild process? Thanks very much for the diagnosis!
