Re: 53 three point wont lift
Posted by Rich on June 13, 2018 at 11:18:54 [URL] [DELETE] :
In Reply to: Re: 53 three point wont lift posted by Doug on June 12, 2018 at 09:03:11:
Hi I've been working with Doug on the lift arm. You show a pic of a unloading valve. what I've seen that is the new style and Doug has the old style. Not sure if that makes a difference. Also on the back pressure valve (the one with the acorn nut)how do you tell if you have flow. That tube goes strait down into the return port am i missing something. On the pressure side of the system there is a relief valve how come we don't see any fluid from that.
Rich
