Re: axle pin diameter 9n-2n
Posted by Rusty 2N on June 13, 2018 at 13:10:23 [URL] [DELETE] :
In Reply to: axle pin diameter 9n-2n posted by chris eby on June 13, 2018 at 04:04:52:
The pin you are looking for is around 2" longer then the newer 8n pins that are at a reasonable price. You have the cast mount, thicker, heavier. If you can weld, easy to make. When i replaced mine I found it a bunch cheaper to make one than a new one that would fit. Later I did discover there was a newer model that used the same pin but don't recall what model it was on. Rusty
