Re: Help, broke my backhoe !
Posted by Tony C on June 13, 2018 at 16:14:57 [URL] [DELETE] :
In Reply to: Help, broke my backhoe ! posted by dave#1 on June 13, 2018 at 14:17:20:
Make them. 3/8" stock? All you really need is a hand grinder with a cut off wheel, bench grinder, drill press, starter drill and a drill the diameter of the hole. From the looks of the other links I'd say that is a high time machine. Make the pin(s) from a grade eight bolt. No real need to relieve the sides. No style points and a higher houlry rate for pretty.
Tony
