Re: Clutch allignment tool
Posted by steveVa on June 14, 2018 at 04:01:42 [URL] [DELETE] :
In Reply to: Clutch allignment tool posted by Tom on June 13, 2018 at 20:23:12:
You need to align the clutch with the pilot bearing and the splines of the clutch when you bolt down the release plate. Otherwise you will never get the trans to line up and go together. You can get an alignment tool or use a input shaft from a trans. Some clutch sets come with a tool or the supplier will loan you one. You should also look at and or replace your pilot bearing while you are in there.
