Re: Cranking but no start
Posted by Jack - Iowa on June 14, 2018 at 06:52:19 [URL] [DELETE] :
In Reply to: Cranking but no start posted by John on June 13, 2018 at 09:51:09:
John, Not sure what the fuel shut off valve is on a Jube. Think it is like the one used on the hundred series.
Regardless I have had good success rebuilding both that type and the one used on the 2N'S.
The Hundred series has a small O ring which can be replaced. Been too long on the 2N! I don't remember what is in it.
Sounds as if you need to get some fuel in it before you try starting it again.
FYI: I NEVER disconnect the batteries in my tractors. Unlike modern cars, they do not have anything continuously drawing current. I doubt the battery is the problem.
Good Luck.
