Re: 1952 8n electrical question; 'spinning generator'
Posted by JMOR on June 18, 2018 at 15:52:10 [URL] [DELETE] :
In Reply to: 1952 8n electrical question; 'spinning generator' posted by Kenneth T. Meyer on June 18, 2018 at 15:20:55:
If wired as original factory ammeter was, then it is a net reading ammeter, so it should have been showing a major negative (discharge) while generator spun with engine stopped. No doubt that the cut out contacts inside the regulator were stuck closed. If it happens again, give the regulator can a sharp wrap & the spinning will likely stop as contacts are jarred open. Key on or off is irrelevant.
