Re: 1952 8n electrical question; 'spinning generator'
Posted by Tim Daley(MI) on June 19, 2018 at 04:23:25 [URL] [DELETE] :
In Reply to: 1952 8n electrical question; 'spinning generator' posted by Kenneth T. Meyer on June 18, 2018 at 15:20:55:
-as mentioned likely a VR issue -is it the original AUTO-LITE unit -see picture below. Belt tension too can affect that. Is AMMETER original induction style? By 'registering more '+' positive' -like more than 10 AMPS? You say after reconnecting the battery and restarting/shutting down engine, the spinning stopped, was OK except the '+' ammeter. When you flip on the headlight switch, does the ammeter show any change? It should show a '0' or NEG (-) reading. It shouldn't matter but can try to polarize generator next time you disconnect/reconnect battery cable before starting up.
