Re: Ford 2 n won't start today but yesterday she did??
Posted by Will on June 19, 2018 at 08:02:14 [URL] [DELETE] :
In Reply to: Ford 2 n won't start today but yesterday she did?? posted by Will on June 15, 2018 at 20:10:22:
Ford 2 n
12 volt system still not charging.
1 I have charged battery with battery charger
2. I had alt tested at car parts store a bench test putting out 14.6 volts
3. I put on a new in dash volt meter wired same as the lot amp meter was wired.
4. I also have been testing system with my portabale volt meter system is not charging
5. I ran a by pass wire from alt output bolt to selinoid battery side
6. I took a jumper wire from post 1 and 2 of alt no change
7. I put jumper wire from alt output bolt to 1 post no charging
I was told conversion to 12 volts was done 20 years ago not sure if it was done correctly or not or if something is not working properly
What shall I do next?????
