Re: 8N water in oil
Posted by Tim Daley(MI) on June 24, 2018 at 16:02:12 [URL] [DELETE] :
In Reply to: 8N water in oil posted by Gary Starr on June 24, 2018 at 11:56:39:
The best way to find out if the block is cracked is to get it stripped down and boiled then Magna-Fluxed to detect any cracks. The worse case scenario is you have a crack somewhere causing the coolant to get in the mix. The good news is if so, and crack isn't bad, it may be repairable.
