Re: My first tractor (8n)
Posted by Jack - Iowa on June 24, 2018 at 18:55:26 [URL] [DELETE] :
In Reply to: Re: My first tractor (8n) posted by Jeff on June 24, 2018 at 08:53:50:
Jeff,
Amazed the other's did not pick up on this! Your diagram shows a Starter Solenoid and a Starter Push Button.
Those are NOT factory original and likely means your safety which keeps the tractor from starting in gear has been disabled. BE VERY CAREFUL! These tractors generally start easily and will run over you.
Good Luck,
Jack
