Re: JMOR
Posted by JMOR on June 24, 2018 at 19:11:12 [URL] [DELETE] :
In Reply to: Re: JMOR posted by Doug on June 24, 2018 at 18:12:08:
Can't function with sticking unloader valve. Not familiar with, " a “sleeve” that is pressed in to convert to the new style".
I believe I read someplace I can loosen the nut on the control leaver retainer and rotate that to get the full range of the lift. Is this correct? ' No, it is not, because the lever/disk that it is attached to will be keyed to shaft. Not reaching full height is most often related to worn cam follower pin or under the cover linkage adjustments.
