Re: Vapor lock on Ford 600
Posted by Farmer Dan on June 26, 2018 at 08:42:03 [URL] [DELETE] :
In Reply to: Vapor lock on Ford 600 posted by Charles on June 26, 2018 at 08:27:03:
Your gas tank is not vented properly or enough. Leave your gas cap off over night so the ethanol can evaporate out of the fuel. If that solves your problem then you need to make sure you gas tank and cap are venting correctly.
