Re: 2N Dilema
Posted by HCooke on June 26, 2018 at 12:36:58 [URL] [DELETE] :
In Reply to: 2N Dilema posted by Del Huebner on June 26, 2018 at 12:14:01:
Hi Del, Can you show here how to check for spark when it dies? Since you have replaced the ignition switch, I would suspect a failing coil. According to John Smith, this symptom of failing to run after 1 hr is frequently caused by a bad coil.
