Re: Vapor lock on Ford 600
Posted by Charles on June 26, 2018 at 15:37:07 [URL] [DELETE] :
In Reply to: Vapor lock on Ford 600 posted by Charles on June 26, 2018 at 08:27:03:
Thanks for all the replies. I have done all as suggested, except kersone.
This carbaratuer was replplaced, with a new one about 5 years ago. Not sure where it came from (origin). Does a carbaratuer have a vent above the float to allow the float to sense fuel level onlY? Is it inside air tube before the vanturie?
Maybe Royse could answer this.
My next dignosis will be to clean out sediment bowl and screen and then if it still happens, loossen the fuel line inlet as thaat appears where it is lacking fuel (same as when it does run out of fuel).
Charles
