Re: 8N running rough
Posted by Bruce (VA) on June 30, 2018 at 18:28:16 [URL] [DELETE] :
In Reply to: 8N running rough posted by Jeff on June 30, 2018 at 15:56:09:
It's nearly July; do you have any gas left in it from the winter? Using fuel stabilizer?
When is the last time you replaced the points, plugs, condenser, rotor & cap and set the timing?
Re the battery, see tip # 49.
Check your generator w/ a meter; see tip # 47. Should be 7.5 volts if it's a 6v system.
Re throttle response, see tip # 14.
