Re: Rotary cutter wobble
Posted by Frank (WNY) on July 05, 2018 at 07:15:14 [URL] [DELETE] :
In Reply to: Re: Rotary cutter wobble posted by Tim Daley(MI) on July 05, 2018 at 05:14:32:
Hi Tim,
Are you talking about the PTO shaft inside of the tractor, or the driveline going to the gear box? The ORC wobbles a bit, but I don't know if it is too much to cause the deck to wobble as much as it does.
I took a better look at the blades, and see that the blades are locked and don't pivot, but are not lined up straight with each other. I am going to take them off to weigh them and free them up so they pivot. The seals are leaking on both input and output shafts, so I plan on replacing those as well.
