Re: 1942 9n
Posted by ncorrigible on July 06, 2018 at 19:16:30 [URL] [DELETE] :
In Reply to: Re: 1942 9n posted by David on July 06, 2018 at 10:00:18:
You will not see the screen on the top of the sediment bowl from the top. Please do as Bruce suggested and at the time of failure take the plug out of the bottom of the carb and see if it fills a pint jar in 2 minutes. If it does it isn't a fuel problem - move on to spark and follow those tips. If it is a fuel problem, it is easiest to start with the screen on the brass elbow on the carb - if it is good, check the screen in the sediment bowl just above the sight glass if it is clean THEN drain the gas and remove the sediment assembly.
Draining the gas for a problem that is further down the line would be just cause for some nasty words directed my way.
