Re: ford 9n
Posted by Tim Daley(MI) on July 11, 2018 at 19:01:56 [URL] [DELETE] :
In Reply to: Re: ford 9n posted by David on July 11, 2018 at 15:59:46:
Yes, some guys have installed Model A or early V8 generators on their Ns -with the Cutout mounted on the barrel. Those have outputs much greater than the N generator rated at 11.5 AMPS. Also, some fellas put 8N starters with the solenoid on their 9N and 2n models too. So you need to verify exactly what you have first. I have some original generators and just finished rebuilding a 2N-10000 unit that will work on your 9N. You need to decide if you want to keep it 6V or invest in doing a correct 12V conversion. Either way you will be investing some $$$ to get it running and running right. My email is open...
