Re: Carburetor
Posted by K.LaRue-VA on July 12, 2018 at 10:06:53 [URL] [DELETE] :
In Reply to: Re: Carburetor posted by BlasterStumps on July 12, 2018 at 04:37:26:
Yep, if the tractor runs fine with the cap off, but begins to stall when the cap is on, the tank vent is plugged. The vent hole is under a small dome at the top of the tank. The vent really isn't accessible even if the tank is completely removed from the tractor. It might be possible to bend a wire and use a mirror to rod out that vent hole working thru the fill hole. Most of us just drill a tiny new vent hole in the fill cap.
