Follow-up on Daughters 2N
Posted by Del Huebner on July 13, 2018 at 10:03:00 [URL] [DELETE] :
From earlier post. The problem with the tractor 6V front mount 2N shutting down turned out to be a bad coil as suggested in the previous post. Thanks for the help. Now the tractor does not charge. Generator has just been checked and repaired at the shop. Getting no charge to a good battery. Can I check the cut-out for voltage with my analog tester if I make contact with both terminals at start up? Belt is tight and I did polarize it. All connections were checked and cleaned. Any help appreciated. Thanks.
