Re: Carburetor
Posted by Theodore Morris on July 13, 2018 at 13:10:20 [URL] [DELETE] :
In Reply to: Carburetor posted by Theo Morris on July 12, 2018 at 04:35:35:
Thank you for all your help. I have found the problem. This tractor was painted gray and the carburetor was painted as well. I do not know how gray paint got inside but gray paint clogged the main jet port. I rebuilt the carburetor, running good and strong now. Now I am having a problem with the charging system. Iím not familiar with a 6 volt system. How much voltage should be coming out of the generator? It is a single post generator. Somebody removed the ballast resistor and I do not know how this is charging the battery. I have to disconnect the battery every time I run it or else the battery will go dead.
