9n Camshaft Gear
Posted by Kevin on July 24, 2018 at 18:00:31 [URL] [DELETE] :
I have a 1939 9N with a stripped camshaft gear that obviously needs to be changed. It is the old style gear where the outer portion of the gear is made of fiber and the center is steel with a large slot in it. Is there a way to change this gear without removing the camshaft from the engine? I have the front timing gear cover off but would sure like to avoid tearing the camshaft out if possible.
