Re: Ford 8N Tractor
Posted by glenn on July 28, 2018 at 14:50:42 [URL] [DELETE] :
In Reply to: Ford 8N Tractor posted by James L. Kille, Sr. on July 27, 2018 at 04:20:48:
I just installed all new tune up equipment on my 52 8n with 12 volt system and discovered after i had done that that my problem was a frayed wire between starter button and solenoid. but after replacing plugs, plug wires, coil, points, condenser, and solenoid it now turns over but I get a violent electrical snap on the starter motor where the heavy copper mess wire connects to the starter motor.
Help.
Things I may have done wrong:
1. hooked the negative pole of the coil to the distributor, right?
2. I put the solenoid on just as the old one was?
