Re: 9n Distributor
Posted by David on July 28, 2018 at 15:13:19 [URL] [DELETE] :
In Reply to: Re: 9n Distributor posted by Tim Daley(MI) on July 28, 2018 at 08:20:46:
Well I did have it assembled incorrectly however that still did not help
what I did was I put the cooper band from the points underneath the concave brass condenser screw I now have it underneath the square insulator but it still will not spark.I wonder if I could have shorted out the condenser? Also should I have power at the generator I get a 6.27v reading at the generator.I have a unique generator with the cut out mounted on top of the generator it is a model T set up.There is 1 wire running to the starter solenoid from the cut out and that is where I pull the 6.27 volts.I would think there should be no voltage there but I may be way off..
