Re: 9n Distributor
Posted by David on July 29, 2018 at 08:30:18 [URL] [DELETE] :
In Reply to: Re: 9n Distributor posted by HCooke on July 28, 2018 at 21:21:41:
Let me try and clarify
the starter solenoid I refer to is the start of the push starter on the floor
not on the actual starter
there are only two wires feeding the ignition one comes from the generator the other the coil
the one from the gen goes to the solenoid the other to the resistor
the one on the solenoid is spliced with another wire that runs to the bottom of the resistor
mine is set up on a neg ground which is opposite from what all I have been reading
I believe that this dist was and is cobbled together because it has a spring clip that was apparently been broken and looks as though it has been filed down by being in the way of a rotating part
I have all the parts to set this tractor up the way it was intended to be but as of now have been holding off on doing so
would all recommend doing that or try and figure it out as is which has been very frustrating
