Re: new dsitributor
Posted by David on August 03, 2018 at 08:24:00 [URL] [DELETE] :
In Reply to: new dsitributor posted by David on August 03, 2018 at 08:17:47:
it has a model A generator on it with the a single wire cut out mounted on the gen.
the previous owner had it set up with a negative ground not sure if that is part of this battle but thought I would share
he also had a 8 volt battery on which he kept removing the positive battery terminal to protect the ignition system so he said
I am new to tractors and just followed his lead
I have both a 8 volt and 6 volt(new) battery for this tractor
