Re: 9n Distributor not the problem
Posted by Bruce (VA) on August 09, 2018 at 16:17:43 [URL] [DELETE] :
In Reply to: 9n Distributor not the problem posted by David on August 09, 2018 at 15:34:22:
" the motor is seized"
So, what happens when you press the starter button?
HINT: if the motor is seized and you press the starter button, nothing happens.
Right?
And to follow up on JMOR's question......how long has this been going on?
How were you checking voltage w/ the points open & points closed if the engine wasn't turning over?
