Re: '64 4000
Posted by Michford on August 14, 2018 at 07:08:39 [URL] [DELETE] :
In Reply to: '64 4000 posted by Tim Daley(MI) on August 14, 2018 at 03:11:43:
The rear tires look pretty worn, so depending on how much dirt work you plan on doing you might be needing rear tires. The clutch pedal looks like it is adjusted to be higher than what you usually see on a four speed trans.
