Re: The Beast is Back (not an N)
Posted by K.LaRue-VA on August 14, 2018 at 07:25:18 [URL] [DELETE] :
In Reply to: Re: The Beast is Back (not an N) posted by Larry Holbrook on August 14, 2018 at 05:36:26:
If I ever bother to pull out a timing light, it is just to back-check where the timing ended up. After tweaking timing a few times using my butt dyno, it's as good as it's going to get without doing a complete distributor rebuild. As long as it's reasonably close to factory spec, I'm going to leave the timing where it seems to run best.
